Dynojet Power Vision, nueva alternativa para inyectadas
FMoW
... si hay que traducir lo hago... es que ahora no puedo, que estoy en el trabajo y es un texto largo.
Fuel Moto is proud to introduce the Power Vision by Dynojet, a true evolution in tuning for 2001-2011 Delphi equipped Harley Davidson’s. The Dynojet Power Vision is not only the fastest ECM flash tuner on the market, it offers the most powerful tuning features. Power Vision features a fully configurable high resolution touch screen that can be either mounted on your bike and used to monitor real time data, or simply used for tuning, logging or storing maps. Power Vision also includes comprehensive tuning software for your computer including an integrated tuning utility called Auto Tune Basic which uses the stock narrowband sensors, and there is an awesome option the Auto Tune Pro which uses the AT-100 with dual Bosch Wideband sensors.
Fuel Moto has been fortunate to be involved with Power Vision thru all stages of development as a technical partner and there are so many never before seen features that I don’t know where to start. We wanted to provide the most comprehensive tuning package available, along with an easy to use package. One of the most unique features is the ability to capture your base calibration and immediately start tuning. With Power Vision you can quickly read the calibration in your ECM, retrieve it, and then edit any table within the calibration as required. You can also choose from the database of pre configured calibrations that are fully updatable thru the update client. There are already hundreds of maps developed, and at the moment both Dynojet and Fuel Moto are working on more calibrations every day.
Here are some of the editable tables and utilites within Power Vision:
Front/Rear VE
Front/Rear Ignition timing
AFR/Lambda (you can display as AFR or Lambda)
Idle RPM
Rev Limiter
IAC Steps
Throttle Blade Control on Drive by Wire models
Injector size
Cranking Fuel
Acceleration enrichment
Deceleration enleanment
PE fuel
PE spark
Warmup Enrichment
Speedo Calibration
EITMS
Knock Control
Adaptive Knock
AND MORE!
... ¿tendrá limite para reducir las rpm? Voy a escribirles y preguntarles. Con lo que me diga os comento.
Parece que si, pero habrá que indagar un poco mas.
Yo les he pedido informacion detallada en español por email.Ya os digo algo.
Bueno, nuestro gozo en un pozo. El límite con este aparato también son 800 rpm... y no recomieda bajar por debajo de 900.
Ejem... me refería al ralenti... la función que indicas es para fijar el corte de encendido... Gracias en cualquier caso, la culpa es mía por explicarme mal :timido:
